While car is on it's wheels:
- unplug battery from car loom
- unplug loom from ECU in boot, pass all leads through rear firewall and into engine bay
- unplug main 12v feed to rear fuse box
(two small nuts hold it in)
- seperate the main engine loom portion of the fuse box
(it slides up and out) so that engine loom is free of chassis
- unplug king lead, and plugs to all the electronic boxes on the rear fire wall
- remove airbox assembly
- undo fuel lines
- remove 12v feed from starter motor
- undo main earth on drivers side of engine
(goes from cylinder head to driver's side suspension turret)
- remove diagnostic port from rear firewall
- unplug engine bay fan
- generally undo anything else electronic I've forgotten to mention that goes between engine and chassis!
- loosen exhasut manifold nuts, but leave a couple on there to hold it in place
(need to remove heatshield first)
Car up and on axle stands:
- remove underbody plastic covers
- drain coolant by undoing the two bolts on the large pipes under the body
- drain engine oil
- drain gearbox oil
- take off wheels
- undo trailing links from chassis
- unbolt rear tie rods from hubs
- unbolt lower arm from rear subframe
- unbolt ARB drop links from ARB
- unbolt exhaust mid section from exhaust manifold
- unbolt rear subframe
(4 long bolts, and 3 going into rear engine mount) and lower by 2
-3 inches
- undo ARB bushes so ARB is separate to rear subframe
- unbolt exhaust midsection from rear subframe, and unplug lamda sensor from engine loom
- remove rear subframe
- remove exhaust
- remove rear ARB
- remove two drive shafts from gearbox, and swing them forwards and sideways, tie to chassis to leave room to drop engine
(worth covering splines with plastic bags to keep clean)
- remove exhaust manifold
(to give yourself more space)
- undo gearlinkages from gearbox
- remove front gearbox mount
- undo clutch slave cylinder from gearbox, I then cable tie this to the chassis to keep it out of the way
The engine/ gearbox should now look pretty clear to remove from chassis- renmove anything else connecting it you can see that I've forgotten- for example the water pipes
(except the final two engine mounts on either side of the engine bay)!
Now I tend to drop the engine onto a pallet using a crane through the engine bay, so take the weight and then undo the two engine mounts.
Then I lift the body with the crane so it's clear of the engine and there's roon to drag the engine out from under it.
This normally causes a clearance issue with the front bumper hitting the floor- so you may want to remove the front bumper first, but with my car I don't tend to bother as the bumper's far from mint anyway!
Off the top of my head that's it- I'm sure I've probably forgotten stuff, like remove the engine lid, rear inspection panels and rear boot lid first!
To be honest it's pretty straight forwards, you'll see what you need to do as you go along
