http://www.mrtwee.nl/MR2.htm
http://www.mrtwee.nl/MyMR2.htm
blackspider wrote:Noticed on the Brochure and spec sheet(on the website Peerke posted) that the engine is 200ps@7,000rpm.
Any idea what Toyota Technocraft did to increase the power? That's almost the same as the Beams engine? I always thought the Spider had a standard NA engine..
blackspider wrote:Would a"Black top" Beams engine from a Altezza fit into a MK2 including the 6 speed gear box?
in the Altezza the engine is mounted vertically in thefront but is still rear wheel drive
.Also they are a lot cheaper to buy than the
"Red top".
A good idea would be a TRD widebody spyder!!! That would be the ultimate 2!!! I think id like to do that someday!!
Antstarr wrote:A good idea would be a TRD widebody spyder!!! That would be the ultimate 2!!! I think id like to do that someday!!
Antstarr wrote:Would a"Black top" Beams engine from a Altezza fit into a MK2 including the 6 speed gear box?
Antstarr wrote:Also I think you will find that picture is photoshopped..
.if u look at the arches u will see its in red.
.looks stunning tho
=D>
blackspider wrote:I think the TRD kitted spider looks OTT.I prefer mine
Since the Beams Red top is soo expensive I think I'm gonna start looking into the Camry V6 option instead..
.Would that make it the only Black V6 Spider?
blackspider wrote:Yes, they were all silver but mine had a full re-spray a few years ago.
