Very quick washer jet question
mr2_tubby
Re: Very quick washer jet question
Post by mr2_tubby »
nice info
KarlBristol
Post by KarlBristol »
Any update about the Volvo washer jets :-k
synXero
Post by synXero »
I have bought a set. Will update before Fri. Total cost £12!!
synXero
Post by synXero »
Very brief write up of the Volvo S40 washer jets:
http://www.imoc.co.uk/forums/viewtopic. ... 37#1479537
KarlBristol
Just to confirm these are the s40 washer jets that you have?
Also your latest pics dont seem to be loading up :-k
synXero
Post by synXero »
KarlBristol wrote:Just to confirm these are the s40 washer jets that you have?
Yeah I bought S40 washer jets.
Odd that they aren't loading... They were uploaded to Photobucket. They load fine for me.
sheep
Post by sheep »
I've tried the toyota yaris washer jets for the last 2 days and im not all that impressed so i will order the volvo s40 jets tomorrow and do a back to back test.
Lefty1991
Post by Lefty1991 »
Put my Volvo jets in today and they work an absolute dream.
100 times better than the standard ones
sheep
Post by sheep »
did you go for the s40 or s60 jets?
KarlBristol
I just ordered a set of the S60 ones.
My reasoning behind this over the S40 ones is that they have the same elbows on them at the bottom of them as the MR2 jets. This means that the rubber tubing wont be unduly stretched/prone to cracking or splitting like I imagine it will be with the S40 ones :-k
The bottom hard plastic connectors of the S40 jets are completly straight. Im guessing more OEM water flow will mean better pressure.
Still - I might be wrong :lol:
Lefty1991
Post by Lefty1991 »
I went for the s40 jets but I had some flexible hose from my last cars washer system so used that to just extend the lines to fit the straight fittings.
You get a full spread across the screen rather than two little squirts
KarlBristol
The S60 uses the same arc spray jets with different connectors I thought :-k
I guess I will be able to find out soon enough :D
Lefty1991
Post by Lefty1991 »
Yeah I'm sure they are, you won't be disappointed if they are anything like the s40 ones, just give the bonnet a good clean when you remove your old jets before refitting the new one
KarlBristol
Front end has only recently been respray so hopefully there aren't any marks under the existing jets... Fingers crossed
To be honest I'm not sure the s60 jets are worth the extra £5 up to the s40 ones just for a bit if bend in the pipe work. I just didn't want to fiddle around with the pipes too much. Lazy or what! :lol:
I look forward to getting my car back so I can stick these on when they are delivered \:D/
synXero
Post by synXero »
My rubber tubing was long enough to get away with it.
ChrisW
Post by ChrisW »
Well I've joined the Volvo S60 washer jet club. Got them from here: click
They're definitely more effective than the stock jets. They'd be perfect if the aim was just slightly higher and I think they need a bit more water pressure - maybe my old pump is a bit tired.
KarlBristol
Did you cut off the small amount of rubber hosing that comes with it?
Good link. I got mine from eBay and they worked out a lot more expensive...
Im looking forward to fitting mine :D
ChrisW
Post by ChrisW »
Yes I cut the Volvo hose off, then the stock hoses fit on perfectly.
cosmos
Volvo V40 D3
Post by cosmos »
Spotted a new Volvo V40 D3 (2013) today and guess what it had three washer jets on the bonnet.
Already bought new MR2 washer jets whats best to seal them as two little pools below them on the plastic trim.
Harold
Post by Harold »
Is anyone aware of a place to buy new washer pumps? Brand new from Toyota they are ridiculously expensive. The flow on my passenger side jet is quite poor and I think it's due to the pump being tired, jet definitely isn't blocked.
