[Mk2] [Turbo] got 2 error codes, any help please
Sparkie
Post by Sparkie »
24
Intake air temperature signal
[THA, E2]
Whenever a short circuit or a circuit detachment in the intake air temperature sensor is detected for over 0.5 seconds.
* Wirings and connectors (intake air systems)
* Intake air temp sensor
* ECU
31
Turbo pressure sensor signal
[PIM, VC E2]
Whenever a short circuit or a circuit detachment in the turbo pressure sensor is detected for over 0.5 seconds.
* Wirings and connectors (turbo pressure sensor systems)
* Turbo pressure sensor
* ECU
i think they might be linked to the AFM as i've changed the filter in the arc, and think i might of damaged it as its so fragile???
Wingers
Re: [Mk2] [Turbo] got 2 error codes, any help please
Post by Wingers »
If thats what you've recently changed then it seems likely.
Both circuits run through the AFM unit so it's more than possible.
Check the simple things first - connector firmly in place etc. but I'd have to agree with your first diagnosis that it's probably AFM.
Wingers
Return to “Electrical”
