[Mk2] [Turbo] Aquaplaning in the Dry?!
Ed209
Post by Ed209 »
Hi all,
Somethings weirds going on, my car seems to be handling v v badly - quite dangerous actually, seems above around 65mph, i seem to be all over the place, as if im skidding..either in the dry or in the wet! anyone any ideas?
KrisMoyse
Re: [Mk2] [Turbo] Aquaplaning in the Dry?!
Post by KrisMoyse »
What's the tread like on your tyres? Quite worn?
Ed209
Post by Ed209 »
KrisMoyse wrote:What's the tread like on your tyres? Quite worn?
The treads fine!
MartG
Post by MartG »
Get the wheel alignment checked, along with the lower balljoints on the suspension
Greddy-Matt
Post by Greddy-Matt »
MartG wrote:Get the wheel alignment checked, along with the lower balljoints on the suspension
Agreed, lower ball joints and worn topmounts cause a wandering feel that on mine needed constantly correcting.
Post by Martin F »
agree, its definately something to do with the steering or suspension...your just going to have to work your way through the above until you see what it is... :-k
Ed209
Post by Ed209 »
ok great, thanks chaps
Caribbean_Blue
Post by Caribbean_Blue »
What suspension you got?? Set to hard will make you bounce across the road.
Bailey
Post by Bailey »
Mine started handling like this a few months ago. Got everything checked by garage. Nothing faulty or in need of replacement. Tyres are fine and alignment has been done.
Got so fed up with it, i just stopped driving it! :roll:
dawolf
Post by dawolf »
My old N/A had a similar problem. Turned out part of the lower suspension arm was loose and needed tightening up.
