Check my garage for updated pics.
However the noise in the engine that I thought was a cambelt too tight now looks to be something terminal in the head
My question is
Also, does anyone have a MK1a enigne for sale in the SW?
firstmk1 wrote:Given the option I'd to fit a mk1b block and head but refit your existing manifold and(all) sensors/ECU/loom.
James_Ward wrote:
Has anyone done this?
System-G wrote:I fitted a 1b engine to my 1a.I wanted the higher flowing injectors in the 1b and I wanted them delivering fuel more agressively using the 1a ECU So just chopped the connectors off the 1a loom and soldered the 1b connectors in place.
We also retained the original inlet manifold as there are some differences in air control sensors and obviously the wiring loom.In fact we landed up using most of the original bolt-on ancillaries as the donor engine's items were in worse condition.
I have been running this engine/setup for nearly two years now.It mostly gets used on track and spends most of it at 7.5k rpm with no major issues.
There is more info on the differences at the top of the page(sticky section)
http://www.imoc.co.uk/forums/viewtopic.php?t=45035
My swap story: http://www.imoc.co.uk/forums/viewtopic.php?t=11218
Forgive terminology in the story, I was very green to this mechanicing at the timeMuch has been learned since
crazylegs wrote:gearbox will be fine with either engine.i`d go for the mk1a loom inlet and injectors.
no snipping wires
,everything fits in place.
the injectors flow plenty of fuel to cope with any fuel demands the engine needs so no worries there.
if you are going to all this trouble in my book its worth a new clutch at the same time.
remember the mk1b has a bigger clutch.the standard aftermarket clutch from you local motor factor is fine.
why not bung a lightweight flywheel in whilst you are at it
dont forget to do the cambelt.it will cost you
£15-20 and only take 10 mins.
so much easier with the engine out.
then you need not worry for another 60k miles.
James_Ward wrote:crazylegs wrote:gearbox will be fine with either engine.i`d go for the mk1a loom inlet and injectors.
no snipping wires
I've already done all this to the engine I swapped in- including a water pump which I believe I bought off've your good self!
The motor was always a bit of a long shot because I got it out of a car I got given for free! Oh well at least the swap should go well because I've had a practice run
The clutch sounds like a plan, it was the only thing I didn't bother with last time- so I can use the larger MK1b clutch ok on the MK1a flywheel or do I need a
'b flywheel? and this fits ok in the
'a gearbox with the
'a starter?
To be honest Fensport are out of shiny low mileage motors so I might buy a complete car that's rusted out and then I can cherry pick the bits and try and recoup some money by selling spares.![]()
Does a lightened flywheel make much difference? Bearing in mind there is nothing else modified on the engine(apart from the slowly reducing back pressure of the exhaust, due to corrosion
) How much am I looking at for a lightened flywheel?
Thanks for all your comments guys I really appreciate it.![]()
