Shortly after buying my MKI MR2 through an ebay seller, I noticed a few
The service showed up signs of either piston ring failure, burnt valves, head gasket or any combination of all three.
I was now looking at having to drop the engine, strip it down completely and starting a full rebuild, which was going to cost a fortune and wasnt worth it for this little car.
I posted my woes on MR2 forums and another member came back offering me the engine from his MKI for next to nothing.
I scouted around for suitable places and all were quoting pretty much the same and eventually settled on MKII MR2 specialists Rogue Systems based in Kenilworth, Warwickshire as they would allow me to be physically involved.
I found out
The late spec engine was in a pretty sorry state when I collected it and it looked like one or two bits would need to be used from my old engine.
Once the engine was dropped off at Rogue Systems, we had a proper look around it and found some corroded pipe work.
The engine before removing it:
9:30am
we then removed the front and back engine mounts, leaving the side mounts in place and had to make sure the engine support stand would balance the engine once out the bay.
We dropped the car down so the engine support would take the weight of the engine and unbolted the side mounts from above and lifted the car, leaving the engine on the stand.
We started stripping the bits off the donor engine for cleaning, polishing and spraying.
We spotted a hole in one of the upper pipes leading from the water pump and replaced it with the identical item from the old engine.
On removing the cam covers from the donor engine, it became apparent the state of it and serious cleaning began.
With the new clutch in place, we then fitted the old gearbox and drive shafts to the donor engine.
Whilst the wiring loom was being prepared for the new injectors and being fitted to the donor engine, I cleaned out the engine bay as best as one could.
With the paint dry on the cam covers, Throttle bracket, Cam belt cover, Plenum/throttle body assy, we fitted them to the donor engine.
Old plenum/throttle body:
New plenum/throttle body:
Started again at 8:30am and finished fitting the plenum/TB to the engine.
By 09:30 we were ready to align the engine for re-fitting.
By 11:00 the donor engine was in place with the mounts secured and we began reconnecting the cables to the engine and plugged the ECU in.
Now this is where the fun began.
Once we were happy that everything was connected, we started filling with coolant and bleeding the system.
The coolant pipe we replaced was leaking at the seal.
Coolant fill part 2 commences.
Coolant fill part 3 commences.
Coolant fill part 4 commences.
Pic of offending part from old engine:
It turns out to be a bolt missing.
We fill the engine with oil and discover the sump is holed
With all connected, levels OK we attempt to start the engine.
The engine seams partially seized! With the gearbox in 2nd, we turn the rear wheel and un-seize the engine and attempt to start again
A new sump was ordered.
So now with the new sump and fresh oil and engine starting and running fine, I collect the car a very happy man
Final engine bay pics:
A very big thank you to all at Rogue Systems especially Matt and Patrick.
Contact details: http://www.revision6.com
A big thank you to John
Thanks to Chris
Also the following for advice:
Paul Woods
Lauren
Kev
And others on IMOC
http://twobrutal.co.uk
