[Mk2] [Generic] Swapping oval and round plugs for alternators
Lewis Jay
Post by Lewis Jay »
Car decided to have a paddy today and the alternator stopped working.
Ah I thought I have one still attached to my N/A engine I will use that.
So I go and take it off and do a comparison, its slightly smaller and the plug is round instead of oval, right I thinks this shall not stop me so I proceded to take the top section of the alternator off and swap it over.
Was a very simply job in the end except the that I had to change the bracket aswell. ](*,) ](*,)
Anyway the point of this post is that if your alternator decides to go t1ts up and you can only get your hands on a round plug and yours is oval (or vice versa) dont dispare as they can be swapped easily, just dont try and use a N/A alternator as you will have to swap the bracket over to and thats a PITA.
How to.........
Remove 3 nuts to take cover off.
http://s58.photobucket.com/albums/g244/ ... rcover.jpg
Remove 4 screws around edge (easy ones)
http://s58.photobucket.com/albums/g244/ ... genuts.jpg
Remove 4 screws (use a good screw drive as they will round).
http://s58.photobucket.com/albums/g244/ ... plugon.jpg
The reason I seperated these to section is because the B+ connector was different between the two, may vary depending on type but you will see when you do it what I mean.
http://s58.photobucket.com/albums/g244/ ... age005.jpg
Finally I had to cut a small section out of cover to allow room for oval plug.
http://s58.photobucket.com/albums/g244/ ... e008-1.jpg
Good luck.
simmo490
Re: [Mk2] [Generic] Swapping oval and round plugs for alternators
Post by simmo490 »
also look at simmos how to about 2 months back :lol: :lol:
see us reme lads are that skint we have to butcher our alternators
Lewis Jay
Post by Lewis Jay »
Worked a treat.
Doc
PM
Post by Doc »
You got PM :)
