Ah I thought I have one still attached to my N/A engine I will use that.
So I go and take it off and do a comparison, its slightly smaller and the plug is round instead of oval, right I thinks this shall not stop me so I proceded to take the top section of the alternator off and swap it over.
Was a very simply job in the end except the that I had to change the bracket aswell.
Anyway the point of this post is that if your alternator decides to go t1ts up and you can only get your hands on a round plug and yours is oval
How to.
Remove 3 nuts to take cover off.
http://s58.photobucket.com/albums/g244/ ... rcover.jpg
Remove 4 screws around edge
http://s58.photobucket.com/albums/g244/ ... genuts.jpg
Remove 4 screws
http://s58.photobucket.com/albums/g244/ ... plugon.jpg
The reason I seperated these to section is because the B+ connector was different between the two, may vary depending on type but you will see when you do it what I mean.
http://s58.photobucket.com/albums/g244/ ... age005.jpg
Finally I had to cut a small section out of cover to allow room for oval plug.
http://s58.photobucket.com/albums/g244/ ... e008-1.jpg
Good luck.
