Looking at the front/rear of my car from a distance and crouching low to look at the outside edges of the wheels, it looks like my front wheels have negative camber on them, as in they are angled out at the top.
I have tein flex coilovers with camber adjustable topmounts.
Is it possible to just jack the car up on both front corners and move this adjustment or would something else need to be changed as well?
On a side note, can the stock setup
(front) be adjusted for camber or do you need camber adjustable bolts to be able to do that?
TIA
