So how much is Mr T gonna charge me for complete rear tie-rod arms or is there anywhere else cheaper that i can get them from.
Cheers Chris
kaiowas wrote:The following bits are common to both:
Tube: 45465-12020
Clamp for tube: 45466-22010
Fixings for clamp: 90101-08265(Bolt) 90170-08125
(Nut)
94511-00800(Washer)
(NOTE
: This is a correction to my previous list of mk1b parts where I missed the washer and quoted it's part number for the bolt, also don't forget that for one tie rod you will need 2 clamps, 2 bolts, 2 nuts and 4 washers.
mk1a specific parts are as follows:
Outboard tie rod end: 45046-19155
Inboard tie rod end: 48709-17010
mk1b parts are:
Outboard tie rod end: 45046-19185
Inboard tie rod end: 48709-17020
Then we come to the large bolt which attaches the inboard end.The EPC lists 3 part numbers for this depending on age but I can't say whether or not these refer to 3 different bolt specifications or whether they just have 3 numbers for the same part
(which happens from time to time).
Nov 84- Aug 86: 90105-12037
Aug 86- Dec 86: 90105-12101
Dec 86- Dec 89: 90119-12130
