When i come to refil my coolant system.. what would be the best coolant of choice?? should i stick with Toyota Forlife? or is there a cheaper equilivant or better alternative??
also, what procedure do i use to Bleed the system?
thanx
if you want to bleed the system go to this link & follow the walk through, I think it says on this link that you need 13 ltrs of coolant but i would check just to make sure. http://www.mr2-tech.com/bgb/mechanical/ ... system.htm
Hope this helps.................
yea bgb kinda helps... but im having to squint my eyes to read it!! i notice it also has the torque settings for all the bolts internal and external of the engine.. but i cant see what they say
has anyone got a 'Blown Up' copy of BGB ??
thanx
