[Mk2] [Turbo] replacing coolant + bleeding ??
RyanRs
Post by RyanRs »
When i come to refil my coolant system.. what would be the best coolant of choice?? should i stick with Toyota Forlife? or is there a cheaper equilivant or better alternative??
also, what procedure do i use to Bleed the system?
thanx :D
Nick Bryant
Re: [Mk2] [Turbo] replacing coolant + bleeding ??
Post by Nick Bryant »
stick with forlife mate,then you cant go wrong
RyanRs
Post by RyanRs »
oke koool... so how about bleeding ??
how much 4life would i need to do the whole system? and how much will it cost?
darkmagi
Post by darkmagi »
if you want to bleed the system go to this link & follow the walk through, I think it says on this link that you need 13 ltrs of coolant but i would check just to make sure.
http://www.mr2-tech.com/bgb/mechanical/ ... system.htm
Hope this helps................. :)
RyanRs
Post by RyanRs »
yea bgb kinda helps... but im having to squint my eyes to read it!! i notice it also has the torque settings for all the bolts internal and external of the engine.. but i cant see what they say :shock:
has anyone got a 'Blown Up' copy of BGB ??
thanx
