Recommendations for wheel alignment please (east anglia)
kieran_sly
Post by kieran_sly »
I'm about to have the top mounts renewed on my Mk2 1990 N/A. As I've never had the wheels aligned before i guess now is a good time. Can anyone recommend a place in Ipswich or near by?
BenF
Premium Member
Re: Recommendations for wheel alignment please (east anglia)
Post by BenF »
Hey, someone else in or Near Ipswich :)
Give Lorven Performance Services a ring and see if they've sorted out access to a four wheel alignment rig.
Failing that, I tend to go down to Elite at Dagenham in London - its about an hour's drive, and they'll be able to sort the alignment. If you can, make sure you've given the rear tie bars a dousing in WD40 before you go so they can be adjusted easily.
