Hey, someone else in or Near Ipswich
Give Lorven Performance Services a ring and see if they've sorted out access to a four wheel alignment rig.
Failing that, I tend to go down to Elite at Dagenham in London
- its about an hour's drive, and they'll be able to sort the alignment.
If you can, make sure you've given the rear tie bars a dousing in WD40 before you go so they can be adjusted easily.
