Corroded sills
Corroded sills
Ok my latest job to do is the drivers sill.
It corroded baldy near the back wheel and the inner part has corroded as well Im gonna plate the inner bit but was wondering if you can buy replacement outer sills for the mk2?
Re: Corroded sills
Yes you can but only from Toyota, they are about
£150 for both sides.
There called rocker panels.
Ive just done mine and i used sills for a micra 93, they cost
£30 the pair from hadrian panels they were aparently the closest match to a mk2 mr2.
They had to be shortened and bent a bit but ive welded them in place nicely over the top of the origional sills.
Re: Corroded sills
thanks for that mate What price where the Micra sills? and when you say they had to be bent in what way?
Re: Corroded sills
JOHNM400 wrote:What price where the Micra sills?
Mr2GtBlue wrote:Ive just done mine and i used sills for a micra 93, they cost£30 the pair from hadrian panels they were aparently the closest match to a mk2 mr2.
Re: Corroded sills
Stupid me! What way did they need to be bent was what i meant to write lol
Re: Corroded sills
The need to be bent to make the curve correct, It is hard to make them fit and if your welding over the top of the origonal sills the wing wont line up to good because the sill will be sitting further out.
so ive had to put a skim of filler on the bottom of the wing to even it out.
You cant tell the difference.
Im probably going to put some side skirts over the top anyways so all will be hidden
Re: Corroded sills
Hmmm I think Opel Manta sills might work for this, but I had mine fabricated from scratch.
mrk 4 golf sills
i have known of a few fitting mark 4 golf sills they are ment to be prety much the same as well, hope this helps
Re: Corroded sills
I needed new sills on both sides, local bodyshop advised that that replacement sills were not available for MR2 so I've now got mk4 golf sills
- they've been made to fit well and look very similar to originals
- cost me a bit of money though.
.not sure if I was robbed or not
Re: Corroded sills
Looks good, ill post a pic of mine soon.
Re: Corroded sills
Well thanks for all the replys guys.
Im leaning towards cutting out the bad bit and underlapping some steel.
Problem is,i really dont want to be able to tell where the sill has been repaired.
I suppose skim filling where the new piece is welded in is the only option.
I like the idea of complete new sills but they sound a big job.
