272 cam base (start point) timing
Century Motorsport
Post by Century Motorsport »
im gonna be fitting my 272 cams soon and just wanna know what a decent base timing would be to set them to. When i get them i will get them degreed up so i just need a figure... ie 106/104 etc etc.
Thanks,
Nathan
Last edited by Century Motorsport on Mon Jul 31, 2006 9:48 pm, edited 1 time in total.
cantfindausername
Re: 272 cam base (start point) timing
Post by cantfindausername »
Do they not come with a spec sheet telling you what they should be set at?
***RIP Car13 ***
*** Now in an Evo ***
Century Motorsport
Good question..... im collecting them on wednesday so maybe ill find out then!! Just forward planning :wink:
They are HKS ones by the way
LJS @ Rogue
Post by LJS @ Rogue »
Yes they do and a cut out and stick to cardboard degree wheel :D
Nod.
cantfindausername
I was unsure of what to do with the cams on mine so just got the values at TDC, set the cams, and plonked the head on. Seems logical to me. :?
***RIP Car13 ***
Century Motorsport
yes i work on the amount of lift @ TDC for cam timing..... never used a degree wheel to be honest!!!
cantfindausername
You'll need the degree wheel to set true TDC.
***RIP Car13 ***
Century Motorsport
Why?? as long as the motor is at TDC and i have the right figures i can set the timing just as accurately by using a dial gague and setting the lift at TDC surely??
I will give the cams to my engine guy who uses a degree wheel and what not to come up with the lift figures at TDC relevant to the desired cam timing.
stevecordiner
Post by stevecordiner »
Use a degree wheel mate ... it's the proper tool for the job. A few degrees makes a huge difference with cams.
I found with a staggered HKS combo, 272 in / 264 ex it can be well worth tinkering with the exhaust cam to bring the power on a little sooner!
Small turbos - they're not big and they're not clever!
Just say NO to small turbos!
