i have just changed my front brake pads and both rear calipers then bled the brakes
testing the brakes driving round the car park the pedal drops quite low on the first press but then if you press again then it becomes firm.
is this something to do with the servo or have i just not bled the brakes well enough? with the engine off the pedal resistance and level when pumped stays the same.
cheers
chris
