fuel tank,
space saver spare wheel,never used
frunk trim that goes around spare wheel,
dash loom
Centre loom
abs unit
Radiator and fans
Radiator pipes
heater pipes
heater matrix
Air con Matrix
air con pipes
dash clocks/cluster
window switches driver and passenger
power steering controler/ecu
passenger door lock
steering column
interior
apexi turbo timer and harness for sw20,
power steering pump
power steering res
lots of bolts and screws.
boot liner
sound proofing in boot
also go a shell
still has good drivers side rear quarter and drivers door
some bits still left on the shell.
can throw all in for an offer for everything
all parts in good condition
probably some bits i have missed.
jamie
