i have these parts left over from breaking my car
fuel tank, £10
space saver spare wheel,never used £10
frunk trim that goes around spare wheel, ( small split) £5
dash loom £10 sold
Centre loom (battery/starter cable) £10
abs unit £20
Radiator and fans £10
Radiator pipes (front to rear) £10
heater pipes (front to rear ) £10
heater matrix £10
Air con Matrix £15
air con pipes ( front to rear) £10
dash clocks/cluster £10 sold
window switches driver and passenger £5 each
power steering controler/ecu £10
passenger door lock £15
steering column £10
interior (minus seats, door cards, dash, steering cowl) including carpets , headlining, rear trim , centres, £50
apexi turbo timer and harness for sw20, £45
power steering pump £20
power steering res £10
lots of bolts and screws.
boot liner £10
sound proofing in boot £5
also go a shell (which cant be repaired) ,which has all glass apart from passenger side door,
still has good drivers side rear quarter and drivers door
some bits still left on the shell.
can throw all in for an offer for everything ( excluding turbo timer)
all parts in good condition
probably some bits i have missed.
jamie
SW20 parts rev 3 turbo
Re: SW20 parts rev 3 turbo
Boot liner? by that do you mean like a plastic liner for the floor ? any pictures?
PM'd too
Sorry I forgot to say all prices plus delivery and paypal
Boot liner as in the boot carpet that lines the whole boot.
Pms replied
Jamie
Pms replied
Jamie
I think if I buy anything else off you, I'll have your full car soon
You got a spare water hose? It's the chunky one that is on the left hand side of the engine bay in the middle that leads down.
Also after the pipe that comes from the turbo itself as mine has a split in it from a numpty tightening up the clip too hard.
That's the one! I just need the rubber hose before the u bend.
For the turbo pipe, yea the big double elbow rubber hose which joins the air filter directly to the turbo. Off the side of it, are two small pipes which go to top of engine and the throttle body I believe.
Post a pic of the turbo pipe and a cost for both. I really do need a loyalty card setting up with you Jamie
Jamitsi wrote:your jamitsi clubcard points total is...
to confirm its the longer rubber pipe?
i have the intake pipe your after
Image Replaced With URL For Quote [url]http://i83.photobucket.com/albums/j291/jamitsi/20160801_184805.jpg[/URL]
£23 delivered plus paypal
do you still have my paypal?
jamie
Your PayPal is engrained into my account of course I have it!
It is the longer water hose yea, but if the other smaller hose on the other side isn't any use I'll have it as a spare incase moving the metal pipe splits it.
Sounds good. I'll send it over now mate
updated
Jamitsi wrote:updated
Got the parts fast as always mate
Gonna try fit make time to fit them this weekend.
Highly recommended seller btw for any others wanting bits. bump
mr2nut123 wrote:Jamitsi wrote:updated
clubcard updated
Do you have the hard pipe cluster that bolts to the side of the inlet manifold for sale? The throttle body coolant pipes run to it.
Dan
Dan
Jamitsi wrote:clubcard updated
Does the boot liner fit an N/A Rev 3???
