Been having an issue since Friday.
Almost sounds like rally style chirp, chirp, chirp but higher tempo.
Does it in or out of gear but only once warmed up.
Checked all the accessories pullies by hand, couldn't feel any movement but the belts were still on.
Hard to make it happen when stationary, need a 2nd person I think.
Clutch doesn't change it.
Sound will continue if the revs stay in the range while off throttle and rolling.
There is a lesser rattle sound while on light throttle.
Have removed the air con belt to rule that out, didn't change anything.
Maybe tighten the alternator a little, not checked the adjuster yet, didn't feel finger lose.
Does the cam belt plastic come off with the engine mount still in place?
Any ideas what could be causing it?
rev 4 uk spec 3sge.
