RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
gmac90 wrote:I removed aircon rad pipes and pump why do u ask?
shinny wrote:gmac90 wrote:I removed aircon rad pipes and pump why do u ask?
Because if you disconnect and remove the pressure switch on the pipes in the frunk, the fans will be always on.When I removed the pipework I disconnected the pressure switch and just left that attached to the wiring.
gmac90 wrote:Sorry to be a bit of a mong but where abouts is the preasure switch? I disconnected my pipes upto where they screw together just coming into the frunk above the power steering ecu.
