Rev1 Turbo
IMR2T
Rev1 Turbo
Post by IMR2T »
Does the standard ECU limit my potential power output?
Is 250bhp realistic with following mods -
- HKS Mushroom
- Mongoose exhuast no cat
- FCD
- Pro Spec II b boost controller
- XS 4" Intercooler
Re: Rev1 Turbo
Yes, providing engine is healthy
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
Is there a guide so I can check whether my TVIS is blocked off or not?
Is it best to block it once a boost controllers fitted?
gmac90
Re: Rev1 Turbo
Post by gmac90 »
Ive herd it is best to block it off... If u seach for TVSV Im sure it will b about.. Intrested to see what hp u get as im in the middle of building my rev1 tubby with similar mods
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
bu88er is it TVIS or TVSV?
What do I have/need to block off on a Rev1?
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
Guys my boost controller allows me to hit 1.1/1.2bar on the low setting.
Is this ok on a Rev1?
Ive no way of knowing if clutch or Pistons have been upgraded by the last owner.
Peter Gidden
Re: Rev1 Turbo
Post by Peter Gidden »
IMR2T wrote:Guys my boost controller allows me to hit 1.1/1.2bar on the low setting.
Fuel maps stop at about 16psi so you're at the limit if ecu capabilities.
TVIS needs gutting/blocking off at 300/320bhp or more.
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
Ah ok, would hate to think what happened when the last owner selected hi boost!
Is there a picture of steps regarding blocking TVIS? Not that I think I nd it at my bhp?
Peter Gidden
Re: Rev1 Turbo
IMR2T wrote:Is there a picture of steps regarding blocking TVIS? Not that I think I nd it at my bhp?
Not that i know of. Remove inlet manifold, remove TVIS plae. Remove spindles and plates. Weld up spindle holes. Block up vac hose to TVIS. Refit.
2mad
Re: Rev1 Turbo
Post by 2mad »
This is far to much for a daily driver .
Just pull the hose and cap it off to the tvis.. leaves it open :thumleft:
The vsv just remove the hose from the actuator and cap it off .
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
Ok big chap, sounds like an afternoons work :thumleft:
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
bu88er, whys this too much for a daily mate?(slightly worried now, lol)
That sounds a lot less work, does that do the same thing as what Pete suggested?
Peter Gidden
Re: Rev1 Turbo
But no advantage to you, in fact, you might even reduce your torque figures.
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
Yeah, that's what I was thinking.
Would still like to know why 1.1bars too high for a daily driver?
2mad
Re: Rev1 Turbo
Post by 2mad »
Stock headgasket for one.. xs power intercooler will still heat soak quite quick (mine did) so you'll be pushing lots of boost for not much reward.
I used to run my ct20b @1.1bar with water/meth , the car felt great , turn it off and heat soak big drop in power :(
Just my 2p sure plenty of people are running 1.1 bar i just wouldnt recommend it.
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
Ah, ok.
I've not changed any settings since I bought the car.
You think I should turn it down till I get it set up by someone I know?
Peter Gidden
Re: Rev1 Turbo
IMR2T wrote:Ah, ok.
IMHO, i wouldn't worry about it. As long as you're aware of the risks of running an engine/drivetrain at more than 50% of it's original maximum boost, go out and enjoy it.
IMR2T
Re: Rev1 Turbo
Post by IMR2T »
I've turned it down for now.
It feels so slow :cry:
I'm keen to build a stronger engine and get a an lsd Rev3 gearbox at a later stage but as it's my main car I'll ease of till I'm closer to building a replacement engine.
2mad
Re: Rev1 Turbo
Post by 2mad »
IMR2T wrote:Ah, ok.
Personally my settings for your mods would be 0.8 bar low and 0.95 high .. these are relatively safe settings and what i run my st205 gt4 on now , till i beef up my cooling then i'll push a bit higher .
The weak link on a rev 1 is the headgasket when increasing boost .
