is it possible do 300BHP with Rev 2 engine and ct26 turbo charger? using Blitz access ecu+apexi AVCR + blitz spec nur exhaust and will do st205 CC
think change wollboro 255 fuel pump aswell
300BHP
Re: 300BHP
probably not on a ct26
Re: 300BHP
if you were to get a CT20B with those mod's you could see 300
Re: 300BHP
ok thanks i have find turbo . think ct20b is cheapest which i can get for swap ??????
Re: 300BHP
I will have one available Tuesday onwards
Re: 300BHP
I've got one too
£250 + p&p
£250 + p&p
Re: 300BHP
Yep done right a ct20b will get you 290+ with your setup
I had same ish setup + afc tuning on mine too and a fpr to drop fuel pressure for the tune.
Re: 300BHP
2mad wrote:Yep done right a ct20b will get you 290+ with your setup
is tt hard connect and setup afc ???
Re: 300BHP
Tomas_St wrote:2mad wrote:Yep done right a ct20b will get you 290+ with your setup
I tuned the afc myself with the help of a wideband o2 .. Just drop fuel pressure so above 4000rpm on boost your near to 11.5:1 and add in fuel with the afc under 4000rpm for off boost and spool .. any rolling road worth a dam can do this
And enjoy the extra hp
Ps. i was running water/meth too .. and that was a big help hp wise .
Just fitting a ct20b and cranking it up will get you good hp with a chargecooler.. its just something to think about .
Good luck
Kev.
Re: 300BHP
2mad wrote:Tomas_St wrote:2mad wrote:Yep done right a ct20b will get you 290+ with your setup
Good luck
Kev.
ok thanks
Re: 300BHP
There have been a number of cars on IMOC that saw 300BHP+ on the dyno running a CT20b with just stock ECU at around 1.2 bar of boost.
So long as the ECU isn't detecting knock and putting you on the 'safe' map, 300BHP is achievable with basic bolt ons.
There are several examples on the 2Bar tuning website:
http://2bartuning.com/dynographs/showgraph.php
Re: 300BHP
Kongaroo wrote:There have been a number of cars on IMOC that saw 300BHP+ on the dyno running a CT20b with just stock ECU at around 1.2 bar of boost.
On a rev3+ yes .. have to try harder with a rev1/2 .
Re: 300BHP
Ah, sorry - I didn't notice the rev 2 bit. Not so simple then unfortunately.
