300BHP
Tomas_St
300BHP
Post by Tomas_St »
is it possible do 300BHP with Rev 2 engine and ct26 turbo charger? using Blitz access ecu+apexi AVCR + blitz spec nur exhaust and will do st205 CC
think change wollboro 255 fuel pump aswell
alanmr2turbo
Re: 300BHP
Post by alanmr2turbo »
probably not on a ct26
Draven
Re: 300BHP
Post by Draven »
if you were to get a CT20B with those mod's you could see 300
Tomas_St
Re: 300BHP
Post by Tomas_St »
ok thanks i have find turbo . think ct20b is cheapest which i can get for swap ??????
gnzyza
Re: 300BHP
Post by gnzyza »
I will have one available Tuesday onwards :thumleft:
Draven
Re: 300BHP
Post by Draven »
I've got one too :thumleft:
£250 + p&p
2mad
Re: 300BHP
Post by 2mad »
Yep done right a ct20b will get you 290+ with your setup :thumleft:
I had same ish setup + afc tuning on mine too and a fpr to drop fuel pressure for the tune.
Tomas_St
Re: 300BHP
Post by Tomas_St »
2mad wrote:Yep done right a ct20b will get you 290+ with your setup :thumleft:
is tt hard connect and setup afc ???
2mad
Re: 300BHP
Post by 2mad »
I tuned the afc myself with the help of a wideband o2 .. Just drop fuel pressure so above 4000rpm on boost your near to 11.5:1 and add in fuel with the afc under 4000rpm for off boost and spool .. any rolling road worth a dam can do this :thumleft:
And enjoy the extra hp :thumleft:
Ps. i was running water/meth too .. and that was a big help hp wise .
Just fitting a ct20b and cranking it up will get you good hp with a chargecooler.. its just something to think about .
Good luck :thumleft:
Kev.
Tomas_St
Re: 300BHP
Post by Tomas_St »
Tomas_St
Re: 300BHP
Post by Tomas_St »
Kev.
ok thanks
Kongaroo
Re: 300BHP
Post by Kongaroo »
There have been a number of cars on IMOC that saw 300BHP+ on the dyno running a CT20b with just stock ECU at around 1.2 bar of boost.
So long as the ECU isn't detecting knock and putting you on the 'safe' map, 300BHP is achievable with basic bolt ons.
There are several examples on the 2Bar tuning website:
http://2bartuning.com/dynographs/showgraph.php
2mad
Re: 300BHP
Post by 2mad »
Kongaroo wrote:There have been a number of cars on IMOC that saw 300BHP+ on the dyno running a CT20b with just stock ECU at around 1.2 bar of boost.
On a rev3+ yes .. have to try harder with a rev1/2 .
Kongaroo
Re: 300BHP
Post by Kongaroo »
Ah, sorry - I didn't notice the rev 2 bit. Not so simple then unfortunately.
