Higher (than 440cc) injectors from other cars?
GreddyMR2
Post by GreddyMR2 »
Hi there,
appearantly my 440cc injectors are too small and I am urgently looking for some bigger ones.
The problem is that I am in Lithuania and to find some 3sgte injectors that would fit rev1 turbo fuel rail, is impossible.
So does anyone know if there is possibility to fit bigger injectors from other cars?
Peter Gidden
Re: Higher (than 440cc) injectors from other cars?
Post by Peter Gidden »
Rev3-5 MR2 Turbo injectors are a straight swap for Rev1-2 injectors.
Al-sw20
Post by Al-sw20 »
Make sure you bore that stock rail out or replace it.
GreddyMR2
Post by GreddyMR2 »
Al-sw20 wrote:Make sure you bore that stock rail out or replace it.
Do you mean I need to bore rev1 fuel rail when fitting rev3+ injectors?
Peter Gidden
Correct. Rev1/2 rail is 5mm bore. Rev3 is 8mm to flow more fuel.
GreddyMR2
Post by GreddyMR2 »
Never did or searched for information how to bore.
Do I need any speacial tools for it?
Peter Gidden
Line boring fuel rails is very tricky. Needs boring from one end to the other.
You can get them from ATS Racing.
GreddyMR2
Post by GreddyMR2 »
I wanted to do everything untill next weekend. But probably I won't make it...
Peter Gidden
GreddyMR2 wrote:I wanted to do everything untill next weekend. But probably I won't make it...
I have a bored out rail here. Sky-net says he wants it. PM him and check if he is definitely buying it from me.
If not i can despatch to you on Monday. I also have Rev3 injectors.
GreddyMR2
Post by GreddyMR2 »
Luckily I got rev3 fuel rail abd injectors in Lithuania.
Now I have a couple of questions.
What should I modify to rev3 fuel rail to fit to rev1?
If it's too difficult, maybe I can just fit injectors to my fuel rail without boring it?
Or is it a must to bore my fuel rail?
I will be running around 1 - 1.1 bar with a hybrid ct20.
Peter Gidden
GreddyMR2 wrote:What should I modify to rev3 fuel rail to fit to rev1?
Change it. It can't be made to fit.
GreddyMR2 wrote:Or is it a must to bore my fuel rail?
Not a must, but you're increasing from a designed 10psi of boost to 16psi. That's a 60% increase.
Toyota incresed rail bore from 5mm to 8mm on just a 2psi increase. Go figure...
GreddyMR2
Post by GreddyMR2 »
What do you mean by saying change it? Do you mean rev3 rail can't be fitted to rev1?
Ok, I suppose I will not risk and get the rail rebored.
Thank you Peter for a fast answer!
Peter Gidden
GreddyMR2 wrote:What do you mean by saying change it? Do you mean rev3 rail can't be fitted to rev1?
Correct.
