Please,has anyone got a simple solution or if it has to come out what is the best way to go about itmany thanks
Leemeg99 wrote:hi i have removed the air intake manifold and i'm now at the point of looking at the injectors.the injector 4 which is causing all the problems looks as if it's been a bodge in the past and has a joint in the lead, the wires appear to be connected the wrong way round,would that stop the injector from firing
many thanks
