Thank you in advance for any advice
thomp1983 wrote:what are you trying to achieve there are alot of products aimed at different areas, do you want to reduce road noise or are you looking at improving the sound of your stereo?
thomp1983 wrote:you'll want some form of mass loaded vinyl then or effectively heavy duty rubber matting glued to the floor pan and bulkheads.to do a decent job will mean adding a fair bit of weight, a stock mr2 isn't too bad for road noise are your a pillars sealed properly behind the tweeter covers they can let alot of noise in also are your windows properly aligned making a good seal with the rubbers and are the rubbers in good condition? and lastly the cars not running really low profile tyres is it?
