First test i tried was E1 and TE1 connected, car warmed up, connected volt meter to VF1 and E1, ran at 2500rpm and it was displaying a steady 0.04v.
Took the car out for another run
This time i got a fluction between 1.07v and 1.08v 8 times in 10 seconds.
Is that test still valid or is E1 and TE1 need to be bridged or should i go and test it again?
If it is an ok test, is that voltage ok and is the fluctuation ok?
