[Mk2] [NA] lead order
hi could you help with the ht leads, took them off to change am i right in saying that from the fireing order 1342 on a rev3, does no1 go to no1 on the cap and so on, thanks, na rev3
Re: [Mk2] [NA] lead order
Odd that no one else has piped up on this one.
Yes cylinder 1 is nearest the timing belt.
Then next cylinder is
#2 then
# 3 with the cylinder nearest the gearbox being cylinder
#4.
The leads then go on the dizzy cap with the corresponding number.
lead order
ok, so thats the lead order, but the fireing order is 1342 so im told,
so lead 1 will go to 1 on cap, 3 will go to2, 4 to 3, 2 to 4,
i think thats right
i think thats right
Distributor cap makes it easy for you.
Plug numbers are moulded into cap.
Plug lead 1 into no.
1
Plug lead 2 into no.
2
Plug lead 3 into no.
3
Plug lead 4 into no.
4.
abovetherim wrote:The leads then go on the dizzy cap with the corresponding number.
