Draven wrote:I also get this noise..
it turns out it is the end of the spring not sitting in the spring cup propperly and it pops out when going to full lock.
Might be the same issue.
nick26275 wrote:Hello, I've only had my car back on the road a couple of weeks following fitting a new subframe and replacing a rear alloy wheel following a fairly heavy slide into a high curb.![]()
My rear camber is still slightly out, but what has really got me stumped is my ABS
'boinging' spring noise seems to happen allot more often.
It used to sound when I pulled away after starting up and that was it but now almost every other time I come to a complete standstill, its there
'boing'.
The brakes themselves feel the same as they always did but I was just after some feedback from other owners is this normal or was the way it was normal? and what could be the problem?
There is no ABS warning light and I have tried checking for ABS faults and there are none.
Any Ideas?
wickermonkey wrote:Draven wrote:I also get this noise..
I get this aswell, glad to hear it might not be something too serious
