I have read that McPherson struts mean it is not critical, but one side looks at a different angle to the other
Just a general question.
Ta.
planted2 wrote:I had this,
the two bolts that securestrut to hub,give a slight in out adjustment of the hub when refitting,just a matter of loosening them off and measuring the gap from hub to strut bracket to get them about right before tightening.
If you want to be more precise there are settings somewhere on here,
and im sure ive seen a how to on you tube using a square and a spirit level.
