Cold start timer/switch is the grey sensor located in the water elbow, you will have 2 facing the rear of the engine
(cold start and water temp sensor) and 1
(water temp for the dash guage) facing the front.
The cold start timer is very easily broken, iirc it's a 22mm ring spanner to remove it.
.the fifth injector that the cold start timer activates can be unplugged to stop the constant overfuelling
, if it's broken.
.this worked for me anyways matey.
.you should be able to pick up a second hand one on here for
£20 or check out Camskill, if in doubt give them a ring and ask for
"straight talking" Mike.
The injector pack is the thing covered in finns thats next to the fuse box in the engine bay.
.unlikely that it's this.
.are you getting a spark?
The fuel will have lost some octane level but won't have gone lumpy, I personally wouldn't drain the tank unless it was coming out for a new fuel pump or the like.
