In the above pic I have a Rev2 3sgte head with a 9 bolt stud pattern manifold.
The Rev3 heads are only a 7 stud pattern which does not use the far left and right studs.
Would I be ok to remove these 2 studs and then use my 9 stud manifold with only the 7 studs and nuts?
