^^^^^^the metal coolant pipes here, you need to disconnect at the turbo end and fols
'em out of the way.
.mine doesn't have a gasket, I have just sealed it with high temp silicone
.works fine, it's been off enough times to show up any weakness.
Bleeding.
.piece of cake man.
.really don't know what the fuss is about.
undo the filler cap half a turn
(pressure off but still attached),
attach(hang) the bleeding pipes to rad and heater points and open the valves,
start car, set heater to hot and leave it to warm up,
the liquid in the tubes will bob up and down, leech bubbles if they're in there and should settle out at the same level.
.doneski.
Looks like your in for another episode anyway mate.
.can you get a little light/torch to show up the split in the dark if there is one
(fingers crossed it's just a gasket prob).
The gaskets that are on ebay look like they're made from toilet paper,
http://cgi.ebay.co.uk/Turbo-Oil-Water-G ... 3486037220
mine is steel like the banjo gaskets.
.as long as it's not bent.
.it won't leak.
.can't find one on Camskill.
