Installing Power Steering into non PS MR2??
JaaN
Post by JaaN »
Hi guys, was just wondering if its possible to install power steering into my mr2? if yes, how much it would cost and is it worth??
jasongtr
Re: Installing Power Steering into non PS MR2??
Post by jasongtr »
the main issue is the part that the steering coupling that attaches to the rack the chassis is different so youll need to weld a ps version in there, i was looking at going the other way to save weight but when i had them both side by side i thought .... nah
a few holes will be needed and then you'll have to bolt the pump up too.
also then theres the electrics, i assume your loom wont have all the gubbings (technical term) for the ecu and controller/relay. and your slip ring wont be for PS as it senses steering wheel movement to switch the ps on i think
too much trouble id say
Rogue
Post by Rogue »
It's possible, and it's something we've done for a customer in the past. The problem is that once you've bought all of the required parts and paid for the labour you could almost certainly have bought a complete replacement car *with* power steering...
pbmr2
Post by pbmr2 »
what about going the other way? i'd like to dump my PS for weight saving reasons.
is it only a matter of chaning the rack, column and welding in a mount?
Rogue
Post by Rogue »
pbmr2 wrote:what about going the other way? i'd like to dump my PS for weight saving reasons.
Pretty much!
arnaud_mr2
Post by arnaud_mr2 »
it's possible!
i'm french and i'm install complet power steering on my mr2 lhd
best regards
arnaud
pbmr2
Post by pbmr2 »
bravo! avez-vous des photos?
thanks patrick, i've got a rev1 to chop up for bits so i'll cut the mount out of that.
hmm having a good day for finding stuff out
:D
JDM-MAT
Post by JDM-MAT »
Have you looked to see if you have p/s fitted and its just not working? Rev1s can have p/s fitted already
arnaud_mr2
i have a complet topic for swap power steering on a french forum:
Mr2racing
Rossi
Post by Rossi »
On the US oc a lot of the owners just drain their powersteering fluid and remove the pump. Using a bung on the bolt. A few have been running the rack dry for years apparently with no problems.
You get the quickness of a PS rack with the feel of a non PS rack at the expense of burning a few extra calories maneuvering at low speeds
I'm gonna try it next month as I ordered one of the bungs for a fiver from HUXRacing.
JaaN
Post by JaaN »
Thank you guys for the info, its seems it's not worth the money, and i can see more people try to do the vice versa, the thing is, im planing turbo swap, more power. I've tried track days with n/a, and its get very hard to control at low speed corners and especially when counter steering, trying to control the slide, it just throws u in the opposite direction its like u can barely hold the steering wheel, i can't imagine the hustle with turbo power and no PS.
