Changing brake fluid tomorrow, I've read a few threads about using 5.1 brake fluid.
The resevoir cap says use dot 3.
Is it safe to use 5.1 so on a standard system regarding seals etc.
Should
dot 5.1 is the only fluid we use at work(toyota) works fine in mine
I've got 5.1, done 5 laps of the nurburgring without any fade.
