Hi all,
Changing brake fluid tomorrow, I've read a few threads about using 5.1 brake fluid.
The resevoir cap says use dot 3.
Is it safe to use 5.1 so on a standard system regarding seals etc.
Should / will I notice any difference
Brake fluid 5.1 worth it?
Re: Brake fluid 5.1 worth it?
i personally wouldn't
Dot 3-4 are pretty much compatable with each other, DOT 5 can pottentially cause problems on older brake systems as it's petrolium based i believe.
Cheers,
Cheers,
Edited wrong link
Try this one .. second Paragragh down
http://www.afcoracing.com/tech_pages/fluid.shtml
Thanks for that link
Yeah Dot 5 is a definate no no because it is silicone based.
Dot 5.1 looks like it is a improved version of dot 4.
Any users out there?
Dot 5 is a no-no as its silicone based and wont 'remove' water from the system however Dot 5.1 will
I will be using 5.1 from when i do my brake change
Cheers MarkR32
Thats +1
Thats +1
dot 5.1 is the only fluid we use at work (toyota) works fine in mine (toyota dont do any other anymore if my memory is correct)
I've got 5.1, done 5 laps of the nurburgring without any fade. Can't say more than that!
Just what I needed to hear.
Even better news, btw what pads did you use and did they survive?
5.1 it is then.
Cheers lads
TBH not sure on the pads, i've just replaced them but the front ones were down to the metal almost, maybe 1mm left.
I've been running DOT5.1 for over a year and it's brilliant. Never had even the slightest hint of fade. I'm running EBC Yellow Stuff all round and Goodridge steel braided brake lines. With decent tyres and coilovers, the stopping power is painful
