Its had new NGK leads and plugs and oil change.
It boosts up max on the guage, but still struggles and hesitates a bit.
No error codes.
willfinch36 wrote:as in my first post, no error codes
I will arrange for a new rotar arm, etc.and then report back.
djpkins wrote:give the coil a once over before you spend any cash..
.and also check for boost pressure leaks with soapy water.
