[Mk2] [Turbo] Boost Issue
willfinch36
Post by willfinch36 »
For a while I have been having an issue, not quite sure exactly what is the issue, but after about 10/15 miles of driving, the car only really uses about 3/4 of its proper power, if you reset the ecu, its ok for say another 10/15 miles.
Its had new NGK leads and plugs and oil change. but still no change.
It boosts up max on the guage, but still struggles and hesitates a bit.
No error codes.
easty-5
Re: [Mk2] [Turbo] Boost Issue
Post by easty-5 »
Get a boost gauge.
Have you dizzy cap and rotor arm?
willfinch36
Nope that was my next port of call though.
easty-5
Post by easty-5 »
I meant to say, "get a boost gauge to see what boost your running"
and
"Have you changed your dizzy cap and rotor arm" lol
Does the car actually missfire? Any warning lights on the dash?
willfinch36
Sorry yeah my next port of call was to change the rotar and dizzy, not exactly a misfire, just a slight hesitation nothing on dash
MR John
Post by MR John »
Check your ECU for codes :) easy as, as said dizzy rotor also ht leads could be leaking :), good luck
willfinch36
as in my first post, no error codes :P
I will arrange for a new rotar arm, etc. and then report back.
MR John
Post by MR John »
willfinch36 wrote:as in my first post, no error codes :P
Sorry dude was reading it on my I phone at work lol :thumleft:
djpkins
Post by djpkins »
give the coil a once over before you spend any cash...and also check for boost pressure leaks with soapy water.
willfinch36
djpkins wrote:give the coil a once over before you spend any cash...and also check for boost pressure leaks with soapy water.
coil.. in what sense the "once over" ?
willfinch36
Which Distributor Cap and rotar arm do I need? I can only find the one for the up to 91 model and the one for past that seems to be 5mm ?? ( on Camskill)
Any Ideas?
Bone
Post by Bone »
djpkins
Post by djpkins »
look for signs of water damage and cracked insulation...and work your way back to the plugs from each lead.
willfinch36
No water damage.....
plugs are fine
compression test = all cylinders 12.5
new HKS radiator cap....
but still appears to be losing water? coming out of the overflow?
But not overheating or anything.... and boost issue/missfire in 2nd gear sometimes.
