[Mk2] [Turbo] After market intercooler gains
Jonnie1987
Post by Jonnie1987 »
Im thinking about buying an after market intercooler as my next mod form my Rev 1 turbo. Due to being on a budget the ebay one will have to do.
Does any one know what gains I should expect with this intercooler over the standard one?
current mods are:
Apexi induction kit
Decat with standard exhaust
Gizzmo EBC (adjusted to 0.79 bar)
Regards
John
Andy F
Re: [Mk2] [Turbo] After market intercooler gains
Post by Andy F »
You will be able to turn your boost up to 14psi if you have a FCD
And you will notice quite a nice difference :thumleft:
Built by YVS Performance
Every car that leaves runs 2 bar+
Jonnie1987
I have an FCD however its not on the car as I am unsure how to fit it. Its the Kelsport one with three wires: Red, Black and Green.
Andy F
Post by Andy F »
I cant remember which wires to connect to, google it
Forgot you will need a descent boost gauge too
then enjoy but dont go over 14psi to be safe!!
Jonnie1987
my EBC has a real time boost read out so I already have the gauge :)
mr2turbo99
Post by mr2turbo99 »
Jonnie1987 wrote:my EBC has a real time boost read out so I already have the gauge :)
Hi Jonnie,
What settings are you using for 0.79bar on your Gizzmo?
I have the same Mods up as you apart from mongoose exhaust.
Jonnie1987
I Can't remember the gain or duty cycle figures right now but I'll let you know later on.
JJ
Post by JJ »
Cut into the PIM signal wire on the map sensor.... Youre FCD is basically a resistor which friggs the signal to the ecu.... 3 wires, 1 from the sensor, 1 to the ecu... the remaining must be an earth.
To be honest, the easiest way is to just unplug the small vac line going to the map sensor.... On a Rev 1/2, it serves the purpose of dash guage and overboost protection. Be advised though, this removes the overboost protection.
If all your vac lines are secured correctly, then its unlikely to come apart and cause overboosting problems.... plus the stock Ct26 will run out of puff before causing any engine problems ! :thumleft:
No more than 14 psi though ! :thumleft:
