I have an intermttent prob with starting.
.well it's happened twice.
Turn the key and the engine just turns over without firing.
.there is a great spark and the car stinks of fuel.
.lol.
.the only way that I have been able to cure it is to undo the banjo bolt connecting fuel supply to the rail, crank it over.
.then it will fire.
.lol.
.rush back and tighten up the bajo bolt fkn sharpish before too much fuel is lost.
.obv this was just an emergency method of starting it up as I was miles away from home both times I had to do it.
When the fuel pipe is disconnected there is stil a constant dribble coming out of the it.
.even when I disconnected the battery earth cable.
.no where near as much as when it's pumping fuel in from turning the key though.
.any and all ideas are welcome guys.
.I thought it may have something to do with the turbo timer not turning the fuel pump off but now I'm just baffled.
.the car maybe feels slighly less banzai mental on acceleration and doesn't seem to pop as it used to all the time.
I was just about to stick a bottle of injector cleaner in it.
.but though I'd post this first.
mines ecu, arc ic, avcr set to 1bar, hks plugs, apexi safc set to neutral, fet turbo timer.
.good rotor arm and dizzy cap.
