I've removed all error codes when using the ST205 ECU
I've found if I disconnect the PSCT pin the power steering pump comes on, however this means it comes on when the engine isn't even running
My question is, what pin/wire in the main ECU can I use as a trigger that will suit these needs?
Most pins usually come on with just the ignition on, without the engine running, where as I want it to come on, only when the engine is running, not before.
If possible, I'm trying to concele all the changes inside the ECU so from the outside it still looks standard.
