[Mk2] [NA] Yet another alternator problem!! Rev 3
Caz
Post by Caz »
Trying to change the alterator, got a new one with the oval attachment but now I can't seem to get it to fit into the pivot bolt mount, is there differences in the sizes? I hadn't seen it mentioned before. It seems to be mm's but its not fitting. losing the plot with it!
Any help would be greaty appreciated!!!
Caroline
Dale_V
Re: [Mk2] [NA] Yet another alternator problem!! Rev 3
Post by Dale_V »
There is 2 further oval types as I remember:
1) large for automatic NA's and turbo models
2) small for manual NA's
toxo
Post by toxo »
Either that or your supplier has mistakenly provided you with a Celica alternator.
going4the1
Post by going4the1 »
Caz - on the alternator bracket there is a fitting which is meant to lock against the alternator when the pivot bolt is tightened. It is on the outer (non-threaded) pivot hole but on the inner face. This fitting is usually seized/rusted in place.
There are two ways around this:
(i) Remove the bracket. The either lever or push the fitting out. And/or
(ii) File down the lugs on the alternator slightly. Half a mm will do.
Return to “Electrical”
