Caz
- on the alternator bracket there is a fitting which is meant to lock against the alternator when the pivot bolt is tightened.
It is on the outer
(non-threaded) pivot hole but on the inner face.
This fitting is usually seized/rusted in place.
There are two ways around this:
(i) Remove the bracket.
The either lever or push the fitting out.
And/or
(ii) File down the lugs on the alternator slightly.
Half a mm will do.
