My problem is with re-attaching the loom! My problems are as follows:
Do the both the starter motor and alt both have two big wires bolted on to the terminal?
There is a black wire which is attached to the gearbox via a bolt.
There is a another wire which looks like the one I just mentioned but grey, which is coming from under the fuse/relay box.
There is a snap on 2 pin grey plug which comes from loom under throttle intake/water pipe connections and I cant find a home for this.
Pls try help, I know it is hard without seeing it.
