I have one with 2
Im sure on the damaged one i recently removed there was just one connection
Just wonder if anyone could clarifie and if there should be two connetions what does each relate too
Dale_V wrote:2 connections, 1 for the bulb and 1 for the steering mechanism.it looks like you now have an import steering fog
Dale_V wrote:I believe so mate, no reason why not, you will just have no plug from your wiring loom to put into the steering connection part on the fog lamp
FASTFORD wrote:
Out of interest what has everyone else used to hold a new Foglight in place?
I used tie wraps![]()
