[Mk2] [Generic] £10 to whoever can lend me this lock nut remover...
skytek
Post by skytek »
Hi chaps,
I'm trying to get a wheel off my old mr2 to put on my current one but when I sold my other car a few months back I gave the guy the wheel nut remover for these wheels by mistake and have no way of contacting him now as he is abroad.
As you can see I have tried welding on a nut and twisting it off that way but my welder is rubbish and my welding skills are even worse so I've given up on that.
So....if anyone here has a remover that will fit and can lend me it for one day and can get it to me by thursday I will send you a tenner for your kindness and I will also return the remover the day after.
Please please please someone say they have one!! :pray: :pray: :pray:
flackie666
Re: [Mk2] [Generic] £10 to whoever can lend me this lock nut remover...
Post by flackie666 »
have u tryed a bigger socket and hammer it on my bust the socket but it works altho it looks like a v small hole
nikaiyo
Post by nikaiyo »
It looks like a Mac Guard lock nut, it might be worth asking at your local tyre centre dude or give the RAC/ AA a call they un did one for me years and years ago, they carry a number of lock nuts (or they did :? )
Or failing that and your apeal on here goes un answered.....
http://www.screwfix.com/search.do;jsess ... =wheel+nut
fearless
Post by fearless »
i think thay are all slightly different paterns on them lock nuts wouldnt make just the one otherwise car thieves would just buy a set for the key and nick your wheels, as for welding on a nut to it looks like you have no gas in your welder or its a gasless mig which really are quite xxxx i used to be a welder lots of guys have used these if it helps you matey :thumleft: :thumleft: :thumleft:
http://www.machinemart.co.uk/shop/produ ... ansion-set
http://www.machinemart.co.uk/shop/produ ... t-grip-set
not sure which ones but sure some people have used these just an idea my friend going to get a set of these myself as supposed to be very good for rounded off heads :thumleft: :thumleft: :thumleft:
i was beaten to it :) :) :)
C50
Post by C50 »
are those miglia evos? i've been looking for a set of them
skytek
Post by skytek »
I've no idea what the wheels are called sorry mate.
simmo490
Post by simmo490 »
you wont get another one like it mate, they are all different patterns,
just get stucvk in there, either chizel it out or undo all the other muts, then prize the wheel from the furthest point of the nut. this shold slowly stretch and loosed up the stud.
it will be easier to get out then
simmo
dan1
Post by dan1 »
an impact driver is prob the best option in my opinion if availabe think can get them at a reasonable price :-k i have used one to remove a similar wheel nut to that one :thumleft: or take it to a garage if poss as they would prob do this for you.
BLZ-8027
Post by BLZ-8027 »
C50
Post by C50 »
skytek wrote:I've no idea what the wheels are called sorry mate.
if they look like these.. they're the evos :lover:
skytek
Post by skytek »
Image Replaced With URL For Quote http://i190.photobucket.com/albums/z264 ... 203/01.jpg
Yea that's them. They came on one of my old mr2s but are a bit scratched now. I thought they were cheapo crapy wheels but I liked them because they were nice and light on the road.
skytek
Post by skytek »
The problem with taking it to a garage is that the wheel is attached to the hub which is attached to the subframe which is attached to nothing lol. When I sold the engine I had to remove the subframe with hub and wheel still attached because I didn't have the lock nut key. So I can't get the whole lot down to my garage unfortunately.
C50
Post by C50 »
i just like the design and you used to be able to get them in staggered fitment. They're quite soft and do buckle easy.
BK have a similar one but not in staggered.
skytek
Post by skytek »
BLZ-8027 wrote:Ive got one of these you can buy for £10 posted
nikaiyo
How do these work for removing any type of lock nut keys mate?
larry93
Post by larry93 »
Hi buddy,
A Ford dealer will have a key for this !.
Thats the same as all the fords use and the master sets are brilliant !.
Will see if my friend at ford can lend me the set to send you.
Otherwise if your in the AA/Rac , give them a call and they have the tool to remove it.
Larry.
FreeFall
Post by FreeFall »
When I bought my '2 it had locking nuts on it. The dealer had done them up so tight that when I tried to take them off one of them sheared, leaving half the nut on the stud. I got some good drill bits and started off really small and gradually worked my way up the sizes, eventually I was able to get a small chisel in there, split the nut and get the wheel off. PITA admittedly but apart from knackering the stud which needed replacing, the wheel was fine.
Just a thought.
Nick
skytek
Post by skytek »
larry93 wrote:Hi buddy,
Larry.
Mate that would be fantastic!!! Thanks! :thumleft:
If only I was a mamber of one of those companies but sadly not :(. I didn't realise they had master sets and stuff like that. I should have joined at Christmas when I was thinking about it! ](*,)
skytek
Post by skytek »
FreeFall wrote:When I bought my '2 it had locking nuts on it. The dealer had done them up so tight that when I tried to take them off one of them sheared, leaving half the nut on the stud. I got some good drill bits and started off really small and gradually worked my way up the sizes, eventually I was able to get a small chisel in there, split the nut and get the wheel off. PITA admittedly but apart from knackering the stud which needed replacing, the wheel was fine.
Just a thought.
Nick
I had a go at drilling but my drill bits wouldn't even make a little hole. I tried 3 different kinds of bit but I'm guessing none of them were for metal. I don't care if I kill the stud as it's going in the bin anyway. I just need the wheel off somehow :-k
paul_4xxxx
Post by paul_4xxxx »
my friend came to me a while ago to get a locking wheel nut off his gto... all i did was hammer a socket over the nut and got it undone with a breaker bar...
try that... the socket will come off every now and then, just hammer it further on and eventualy u will get there
Steve-O 2007
Post by Steve-O 2007 »
dont know if its been suggested but Get a similar one and hammer it on hard, this it what my friend did when he lost his
