you can think its full but if you dont check before you set off each time if its leaked out somewhere of a period of a few days the level could get too low then youll overheat.
just a thought.
you had a sniff test done for HG?
also has been known to be cracked block this is usually on rev3's the HG tends to hold up being steel, but the block can crack, thinner wall thickness.
Phone 3S 01252845645 and run you problem by them they'll be able to give you an idea
