Ive heard that the 3sgte engine is sensitive to plug type and fuel.
Or the other thing I was thinking was map sensor or vacuum leak?
dunc982 wrote:I think it was a grey smoke, I carnt remember, will check tomorrow.I checked the oil level and it was fine.
Do you think its the symtoms of a dodgey oxygen sensor?
dunc982 wrote:Yep its firing on all 4, like It say it revs up smoothly.Boost leak is a possibility, I will check the pipe work over tomorrow.
Any more suggestions?
